Nesting to a panel saw
2/3/22
Any suggestions on a decent software that will nest and post to a Giben Smart 65?
2/3/22       #2: Nesting to a panel saw ...
I know people who like Ardis.
2/3/22       #3: Nesting to a panel saw ...
Thanks.
2/4/22       #4: Nesting to a panel saw ...
Rob Young  Member
Dropout- Do you have an optimizer on your Giben? The Macmazza saws we carry have a built in optimizer that does a far better job than a 3rd party software. Part sizes, quantities, material type, and wood grain can be imported with an excel document. Some of the Giben saws had something similar, perhaps this is an option for you.
https://nutekmachinery.com/macmazza.html
2/6/22       #5: Nesting to a panel saw ...
Beta CNC Member
Website: https://forsuncnc.com/
The CNC controller is the brain of a CNC system. It is numerically controlled (CNC) devices that control machines and processes. A controller completes the all-important link between a computer system and the mechanical components of a CNC Router machine. The controller’s primary task is to receive conditioned signals from a computer or indexer and interpret those signals into mechanical motion through motor output. There are several components that make up a controller and each component works in unison to produce the desired motor movement.
Common CNC Router Controller Software: Syntec, SIEMENS, NC Studio, DSP Handheld Controller, OSAI, Fanuc, Mach3, etc.
2/7/22       #6: Nesting to a panel saw ...
Acctek  Member
Syntec Controller
The system stability is very good, the function is powerful, the operating software is simple and easy to learn, and the man-machine operation is friendly.
Professionally used in high-end CNC engraving machines, the anti-interference ability and control accuracy of the control system are better than other types
2/8/22       #7: Nesting to a panel saw ...
Joe Knobbe
Dropout, as mentioned - Ardis does a very good job and we used cadcode with cabnetware, cabinetvision, excel and some other software to post to our Mayer saw with excellent results. We labeled in real time as well.
What software are you using to create the parts list? What are you cutting?
Cadcode
    • Template Services
    • Better Vacuum Cups, Inc.
