What kind of a machine for a small wooden part
2/8/22
Arto
I have been manufacturing a wooden part, roughly 70mm long, 65x35mm.
The grain goes in the 70mm direction.
It is like an oval, with holes drilled through it to the direction of the grain.
I am currently making these on a normal homag cnc, with a jig that holds a 900mm piece of wood vertically (from floor to the work area). When the piece is done with the outside shape and holes, its cut of. Than i rise the piece of material and start over.
I would like to have a machine, that vertically feeds a longer piece of lumber, and has vertical spindles for the operations. Seems like the best way in my opinion to do it. Kind of like a metal lathe with live tools and a bar feeder. Just i dont need the lathe here, just a feed and horizontal tools.
Buying another huge machine for these small parts seems kinda dumb. Would prefer something more suited for this kind of work.
Kinda like a cnc tenoner with more tools and automatic feed.
Anyone know any machine like i describe here?
2/8/22       #2: What kind of a machine for a small ...
Mark B
Maybe look into farming it out to a production mill-turn shop that can turn/re-fixture very quickly. Sometimes farming out work to a specialized shop is more profitable than the work of brining in a machine for single op.
2/8/22       #3: What kind of a machine for a small ...
Why not cut your blanks first to rough thickness. Build fixtures to hold several on the cnc. You would get a more efficient work flow and you could break the machining into two zones where an operator can be loading one zone while the machine is working the other.
Vertical feeding is bound to be inaccurate and limited to one at a time machining.
2/9/22       #4: What kind of a machine for a small ...
Arto Member
Tom:
That is what i do at the moment. A machine working the way i describe would not tie the ooerator so much.
Mark: Do you know which brand machines those kind of shops would use?
2/9/22       #5: What kind of a machine for a small ...
Acctek  Member
AKM1325C1 with 9.0KW ATC spindle and 8pcs linear type auto tool changers, while improving production efficiency, it can also save labor costs, which is suitable for mass production.
https://www.acctekgroup.com/atc-cnc-router/Economic-ATC-CNC-Router.html
2/9/22       #6: What kind of a machine for a small ...
Dan  Member
This post reminded me of something I'd seen on Instagram a while back. Not US based, but this could certainly make the part that you're referencing. (link below)
Instagram Link
2/9/22       #7: What kind of a machine for a small ...
I assume you have some kind of vise that is holding the 900mm piece.
Can you turn vacuum on and off with M codes?
I would use pneumatic or air vise control by an M code somehow. May need to get creative but I'm sure there is a way.
Nest make a tool that will slightly grip the 35mm by 65mm end of the blank.
When the first part is finished, load your super custom gripper tool.
Spindle speed zero.
Drop the spindle down until your super tool grabs the top of the blank.
Use M code to open the vise
Move Z axis up 70mm plus 2 or 3mm so you can kiss the top for accurate length.
Use M code to clamp blank.
Raise Z axis off the blank.
Face top of blank and cut part.
Repeat until 900mm used up.
You could just bolt a gripper to the gantry somewhere with the appropriate offsets and not use the spindle.
If you don't understand what I am talking about google bar puller cnc lathe and you'll figure it out.
    • Country Saw and Knife
