Panel saw variation
3/6/22
Good morning All.
We're just getting used to a new (to us) Giben Smart 65 panel saw.
I did a test cut of 10 100mm 1/2 melamine parts and got variations of 99.2mm to 99.8mm with most of the parts in the 99.5mm 99.6mm range.
Is this within the range of normal?
I'm also having some issues with the scoring blade. Sometimes the bottom is perfect, sometimes chipping on the front of the part and sometimes on the back. That makes no sense to me. Any ideas?
Thanks in advance.
3/6/22       #2: Panel saw variation ...
Rob Young  Member
Who installed your saw? All of these could be the result of an improper installation. Leveling, squaring, pull back test, setting the absolute position, all of these things must be properly done if you want a reliable and accurate saw.
3/6/22       #3: Panel saw variation ...
We installed it. We install all our own CNCs so took a shot at this.
It's square and level.
What's a pull back test?
3/7/22       #4: Panel saw variation ...
Rob Young  Member
The pull back test is used to ensure the pusher pulls back exactly parallel to the fences. Measuring an X pattern on the beams isn't accurate enough.
Regarding the sizes of your parts... The first thing you need to check is the absolute positioning. This will set the first piece accurate. If the incremental cuts are consistent but off in size than you will want to change your saw kerf. Afterwards recheck the absolute measurement and reset it if necessary.
Beam saws are one of those pieces of machinery that everyone thinks they have properly set up but there are fine details that make the difference between 100 percent accurate size, squareness of parts, a saw that doesn't wear prematurely and a saw that is close and likely to wear prematurely.
3/7/22       #5: Panel saw variation ...
Thanks.
3/7/22       #6: Panel saw variation ...
Does it use a tapered scoring or stacked scoring blade? Most common complaint is tapered scoring blade and bowing stock.
3/9/22       #7: Panel saw variation ...
yaakov
0.2+- mm(not inches) can be normal ,not because machine ,only because material cutting behavior
about scoring , first check if beam press enough on yours part
when you cut one so small piece and beam is so long ,and othere side also there pneumatic cylinder( even there bar inside to balance 2 side) there can be alway some 0.0 that one side press more ,then can get this scoring problem
firs solution is go up little with scoring
there some beam saw know to control pressure according part size
try pu small part on other side to be sure its not because that
beam saw its not cnc you can never get perfect diagonal ,or perfect size
(this according many years experience with selco)
3/14/22       #8: Panel saw variation ...
Acctek  Member
It should be debugged and tested many times before use
3/12/25       #9: Panel saw variation ...
Leon van diepen
How do u remove scribing or main cutting blade smart 65 ? Manual shows you plug in an air supply to middle of locking nut .ours has only a large Lnkey hole for just Lnkey tool .still cant figure how to keep saw carriage held up for easy access to lnkey hole .
3/12/25       #10: Panel saw variation ...
Post or DM me pics of your set up.
There is a valve mounted on the carriage that needs to be manually activated to raise the blades for access.
Hit E stop first.
There is a button on the screen that is supposed to do this but I could never get that to work.
3/12/25       #11: Panel saw variation ...
Leon van diepen
Thereis an adjustable screw at top ofmain up/down air ram for carriage .is this it to manually raise it . Ill mark it turn all way in or out count turns so i can go back to original setting . See if raises it ?
3/12/25       #12: Panel saw variation ...
Leon van diepen
Photo of valve
3/12/25       #13: Panel saw variation ...
Leon van diepen
Photo of valve
3/12/25       #14: Panel saw variation ...
Leon van diepen
3/12/25       #15: Panel saw variation ...
Dropout
That's the cylinder not the valve. Please don't touch any of that.
I'll post pics tomorrow.
3/13/25       #16: Panel saw variation ...
Leon van diepen
Cheers 4 help . No one here now has ever changed scribing blade it is 4.6mm main cutting blade is 4.2mm .just want to change scriber to approx 4.3mm .we have plenty of spares bot no one knows and the ones that would know r long left the company so im the next guiney pig teying fix it .
3/13/25       #17: Panel saw variation ...
3 pics.
1 with saw carriage down
1 with saw carriage up
1 of the valve that you need to manually trigger to raise carriage
    • Machinery Associates
    • Country Saw and Knife
