Omal HBD 1550 - Albatros
4/1/22
Lynn
Our dowel machine will not insert the dowel and throws out an error. It says "dowel rotator no correct" I have checked everything I know. Any suggestions or clues on this error code?
Thanks for any help.
4/1/22       #3: Omal HBD 1550 - Albatros ...
Louis Seville Member
you are going to need take the plunger apart the push rod mechanism, and replace the damper and piston seals
Also, clean all the dowels out of the hopper and vac all pcs of dowel out of the hopper
Take apart the nylon feed tube and make sure to seat properly It will time out and send the error when it hesitates due to clogs
4/1/22       #4: Omal HBD 1550 - Albatros ...
Lynn
Thank you so much. I will try these next week.
4/4/22       #5: Omal HBD 1550 - Albatros ...
JKL Machinery
Website: http://www.jklmachinery.com
If the suggested remedy does not solve the problem, call SCM Duluth, they are the service provider for Omal
Good luck
    • Machinery Associates
    • Country Saw and Knife
