Unique 2700 CNC door machine used a a cope machine?
4/11/22
Tipper Member
So I have an older Unique 2700 CNC door machine. It’s not a typical CNC but rather a machine created to automatically cut and profile door parts for 5 piece cabinet doors.
I don’t use this machine any more due to buying some other machinery that is more efficient at making cabinet doors.
However one machine that I could use would be a dedicated cope machine for coping rails on my 5 piece cabinet doors. A new cope machine would run roughly between $25k and $30k for a basic no frills machine.
I am curious to know if it would be practical to use this old Unique 2700 as a dedicated cope machine? Anyone have experience with one of these?
4/11/22       #2: Unique 2700 CNC door machine used a ...
ScottO
Just wonder what is your process for making doors now? What machinery are you using?
I have never used the Unique 2700, but it does have a dedicated cope cycle on it so I think once setup it would work fine for that process. The machine is quite large though so would take up lots of space.
I have owned and used a bunch of Unique equipment including a double end coping machine. It does a fantastic job but as you say they are expensive. I do not know how many doors you do, but personally I can cut copes quickly and efficiently with a good coping sled and a shaper.
4/11/22       #3: Unique 2700 CNC door machine used a ...
It would work well for that. Depending on your cut sequence you could line up several stiles and do multiples at a time. Just back up the last one in the row to avoid blowout.
Having a tool changer is a big advantage. If arched top doors come back (and they will eventually) that machine will be nice to have.
4/17/22       #4: Unique 2700 CNC door machine used a ...
The PMK coper is a pretty slick unit. I've had mine in service for 3 months or so, wish I would've gotten it a lot sooner.
It is fast, and stupid easy to operate.
Not much bigger foot print than a shaper.
HSK spindles, changing profiles takes about a minute.
I paid $27k I think. Used. I had to rebuild the clamp assembly. New I think they're pushing $60k now.
Setting it up as unpleasant and time consuming.
4/22/22       #5: Unique 2700 CNC door machine used a ...
Acctek  Member
Maybe it would be useful to go to the used machine market to post information about your machine
    • Template Services
    • Charles G.G. Schmidt Co.
