Aftermarket safety mats?
5/16/22
James Member
Hello all!
We have an older Biesse Rover C, and we need to replace a few of the safety mats. Does anyone know what I need to look for when going to the aftermarket? I've found a bunch of options, but I don't know if there's specific specifications I need to look for, or if any will work and I can just put my own connectors on to fit the machine? I've looked at our mats and there's no identifying info on any of them.
Thanks in advance for any suggestions!
5/17/22       #2: Aftermarket safety mats? ...
BH Davis  Member
It would seem that the safety mats are simply normally open switches that close under the weight of the user. Assuming the mats have a cable that plugs into a jack/port on the machine you could likely test this by unplugging one and doing a continuity test on it while off the CNC.
If it proves to be the case that the mats are nothing more than a normally open switch then any similar mat would do the job. If the continuity test fails to function at all then likely there are other electronics embedded into the mat. That would mean of course you would have to stay with the Besse part or an equivalent.
5/19/22       #3: Aftermarket safety mats? ...
Mack M Member
If you have employees, do not modify safety devices. Just purchase the correct parts from the machine manufacturer. The liability is not worth the cost savings.
5/19/22       #4: Aftermarket safety mats? ...
christian
we have brought oem gamma mats in
contact to discuss
regards
christian
7/20/22       #5: Aftermarket safety mats? ...
Mike McClaran
We have what you need. Bettervacuumcups.com
909 606-0140
    • Machinery Associates
