Biesse vs omnitech
6/5/22
Chris Maendel
Hey guys I'm looking at getting my first CNC
I'm a small 1 person shop that dose cabinets and some wood machining
I'm looking at a used 2014 biesse klever 1530 and a 2013 omnitech spectra
I'm wonder what you guys think would be the better machine
6/6/22       #2: Biesse vs omnitech ...
Rob Young  Member
Chris
I won't recommend one of the two machines over the other simply because Nutek Machinery imports and distributes machinery. I wouldn't want to get caught up in battles between other distributors.
That being said, you will be a new CNC owner and will need support on a used machine that is already getting close to a decade old. Some companies in our industry do a better job supporting the second or third owner of an older machine than other companies do. Some will require you pay for a service contract. A good place to start in my mind is to talk to both Anderson and Biesse and get a feeling of how you will be treated and what it will cost you. I would definitely bring in a technician from the company you go with to set up your machine and train you.
Best of luck as you move forward with your business.
6/7/22       #4: Biesse vs omnitech ...
Chris Maendel
my problem is with my budget witch is around 40k
6/7/22       #5: Biesse vs omnitech ...
Hen Bob Member
We have a 2014 Klever 1530. I have nothing but good things to say about it. Obviously when buying any used equipment there are unknowns and risk involved, go see the machine for yourself. Biesse support and parts are top notch.
6/9/22       #6: Biesse vs omnitech ...
Jim Kolar
I have a 2006 omintech still running today. Anderson has been very good with support when I have had to call. The machine has been a good investment and very stable. Rob has a good point about calling Anderson and Biesse and see what the cost would be for support. Make sure to add to your budget for the tech to come and go through the machine and train and maybe some parts cost.
Good Luck.
    • Machinery Associates
