which program can quickly check the DXF files
6/14/22
MrKyle Member
Please tell me which program can quickly check the DXF files to find out the minimum distance between objects in the drawings.
For example, for cutting metal 3 mm, set a minimum distance of 3 mm and highlight all the lines in the drawing that are close to each other and the plasma can burn the metal.
There are a lot of files. I want to be sure that I will cut, because the metal is expensive.
6/14/22       #2: which program can quickly check the ...
I have never seen a program that will inspect files for space between vectors in a random DXF. It would seem difficult if its not layered.
I would think it would be much more reliable to just import the vectors into your nesting software and nest them with the parameters that work for your machine. We pretty much never simply run from a dxf someone has supplied to us as they have no idea what criteria we require for nesting.
6/14/22       #3: which program can quickly check the ...
Where do the files come from?
A client or do you make them yourself?
6/14/22       #4: which program can quickly check the ...
jerry Member
Try downloading Vectric V Carve or Aspire demo it has all the features as the Paid version but you can not make cut files. It has the measure tool
6/14/22       #5: which program can quickly check the ...
Vcarve and aspire (own both) still do no have the capacity to import a dxf and qualify/highlight which vectors are within a given distance/offset of each other. The OP is looking for a piece of software that will scan a DXF and highlight any vectors closer than xx value to another vector.
Ive not seen any software that has the capacity to do this. Beyond that... after that process you would then have to go in and MANUALLY move each vector away from its neighbor which would be a nightmare.
The simple solution is import the DXF's into your CAD software and nest them with the appropriate offsets for whatever tooling/machine your running. Its just that easy. If its several pages it is what it is.
6/15/22       #6: which program can quickly check the ...
jerry Member
Just highltght all vectors and try to make a tool path with the size you want to check. Both vcarve and aspire will open dxf's you don't import them
    • Machinery Associates
