CNC wave. Magic sushi board.
6/14/22
Adea00Leka Member
I decided that I wanted to try and recreate sea waves using my CNC machine and thought that creating a sushi board with a waved surface would look really cool.
In order to make the actual Sushi Board, I followed this work process:
1. sketch out the shape of the board
2. extrude just the parts of the sketch that I wanted to be wavy
3. split the extruded body using the wave surface as the splitting tool
4. extrude the platforms where the sushi sit to a lower level
5. use the loft tool to connect the platforms to the rest of the board
6. round the platform edges using the bevel tool
View higher quality, full size image (1042 X 577)
View higher quality, full size image (959 X 636)
View higher quality, full size image (677 X 668)
https://virmer.com/catalog/cnc-milling-machines/milling-machine-wattsan-0609-mini/#gallery-2
6/16/22       #3: CNC wave. Magic sushi board. ...
Michael Member
Well done. How long did it take?
6/16/22       #4: CNC wave. Magic sushi board. ...
The effect would be more dramatic if you carved the back and kept a consistent wall thickness.
6/20/22       #5: CNC wave. Magic sushi board. ...
MrKyle Member
I agree with RichC. It will look better.
6/27/22       #6: CNC wave. Magic sushi board. ...
Adea00Leka Member
Thanks for your advice! I'll сorrect my mistakes on next time.
