Omnitech Selexx Pal w/810d- PLC, NC, Pop Up Pins.
7/9/22
Mario Member
I purchase a omnitech selexx pal with siemens controller 810d it's running the program through a Windows 98 computer. Please excuse my terminology if it isn't the correct wording.
I have trouble with the popup pins, I have read the documentation that the paper came with. In another post, it mentioned it was Code M81-M83 within the MDA window to make the pins work again after zeroing the Z axis. But on the documents that I have, it has M61 as "All Pop-Up Pin Up Enable" and M61 "All Pop-Up Pin Up Disable" and M71 and M72 for the second set. M83 is not listed, and it doesn’t do anything. Granted it was a different machine Omnitech Mate. So I am stuck.
After checking for any leaks in the system, clogs etc. None found. I can active the pins manually, but I can't get them to work from the computer. Others have mentioned that they installed a switch as a bypass, but I rather not deal with that just yet.
On another topic, I am curious on the process of reloading the PLC and NC is. I am in the dark and worried that it would take a few weeks to get back up. I would like to get ahead of any impending issues
Sidenote-
I have upgraded some key part in my windows 98 system.
My floppy drive to a Gotek usb floppy emulator- I can use a 128GB USB with no issues.
Cloned and transfer the Windows Partition to a PATA SSD hard drive, for speed, space and reliability.
7/9/22       #2: Omnitech Selexx Pal w/810d- PLC, NC ...
Have you tried the codes in MDI mode?
7/9/22       #3: Omnitech Selexx Pal w/810d- PLC, NC ...
Mario Member
Yes I have but Nothing happens.
7/10/22       #4: Omnitech Selexx Pal w/810d- PLC, NC ...
Rob Young  Member
Mario,
I have been in service and repair since 1982 and in the wood working industry since 1990. I have seen this scenario over and over again. You have purchased a machine running on Windows 98. I know budgets are tight and everyone wants to save a dollar but I personally wouldn't have considered such a purchase under any circumstances. Better to wait until something newer comes along you can afford.
That being said the reality is you have this machine and now you need to try to get it running. I'm not sure what kind of shape your machine is in mechanically but the first thing I would look into is a quote on upgrading the machine controls. It may not be worth the money to do it (I doubt that it is because of the age of the machine) but having that information will at least give you an option to keep your machine running for a longer period of time. Many of the CNCs using Windows 98 are structured to work with 8 bit software. Newer versions of windows are 32 and 64 bit and the software running the machine just won't work with newer versions of windows. As soon as your computer gives out, and it will, you will have a major headache trying to get a Windows 98 computer that can run your machine.
For the correct list of M and G codes being used on the Siemens controller you should contact Anderson America and ask them for the list. Siemens controllers differ from Fanuc controllers like you will find on the majority of the Anderson CNCs so information you find online regarding the codes being used will be wrong if they are the codes being used by the Fanuc controls.
7/19/22       #5: Omnitech Selexx Pal w/810d- PLC, NC ...
Mack M
Mario email me at cncrouter1@aol.com and I will send you some old files I had archived. Machine codes and a few program code examples.
5/12/23       #6: Omnitech Selexx Pal w/810d- PLC, NC ...
Nathan
On my machine (Omnitech Sellex mate Fanuc control) the pins will only come up if either the x or y is in the home position.
    • Machinery Associates
    • Country Saw and Knife
