NEW CNC Recommendation for Mostly Cabinet Production
3/14/22
Rich Member
Website: http://www.perfectocorp.com
Hey Team,
After about a month of CNC Router research, I about to pull the trigger soon a CNC Router.
Shopsabre IS 510 (Very Likely)
New TalentTD4
Hendrick CNC HLD-L
This will be used for high end Low volume cabinet / closet production shop. Is there something that will give me a better cut / finish That i should be looking into? I understand the machines above may not be high production machines. I am more concerned about the quality and staying within my all in Budget of $80K including vacuum pump.
Ive researched and quoted about 2 dozen machines, most are $100k+ Range , which I rather not, unless i really really have to.
Thanks!
3/14/22       #2: NEW CNC Recommendation for Mostly C ...
BH Davis  Member
Did you check out CNT Motion? As shown in photo $68,000. 12HP HSD spindle. Regenerative blower. WinCNC control software. Enroute 6. Long established, well respected company making industrial machines.
https://cntmotion.com/solutions/application/cnc-router-950/
3/14/22       #3: NEW CNC Recommendation for Mostly C ...
Rich Member
I actually do not have that on my list, I will certainly review it. Every-time i research CNC's i discover a new company. Have you worked with their machines before?
3/15/22       #4: NEW CNC Recommendation for Mostly C ...
I would keep an eye on the decibel rating for the vacuum pumps specified. Long term the noise has an impact on the quality of life in the shop. My pump is an oil type Busch. I have had a FMT cnc for 12 years. It has been problem free from day one.
Much of your time savings will be in sheet loading and unloading. Plan your space for efficient material handling and you will minimize time between sheets. Don't neglect dust collection. I recently upgraded my DC and it had reduced the time I spend cleaning the table before loading the cnc.
3/15/22       #5: NEW CNC Recommendation for Mostly C ...
james e mcgrew  Member
SS, CNT, Freedom and My Machine Camaster are all in the same category of machines, I do exactly what you will be asking of yours and in 10 years my machine has yet to have a problem (only 1) which i was not back in operation within 48 hours (Fed ex timing).
The Camaster has lifetime support, You will need to learn your machine and operation, yet after a period of time some companies will require hourly rates for support.
Camaster provides a support forum which has grown to be probably the largest resource by members of any out there, there are literally hundreds of thousands of post and topics and 60+ thousand members who watch to learn and help at all hours. this comes real handy on a late evening or Saturday when you are trying to get something done and something happens you do not understand (and that will happen)
All of the machines you listed Cut well and the same. it is a matter of strategy beyond the HP or servos to produce good results. You will be doing a lot of study on bits feeds, rpms and materials, for this it will be good to have a lot of friends who understand your machine. when I started the cnc path in 07 I was basically illiterate to the (As I called it) the Voodoo language of CNC, yet the CNC made the difference to survive the recession and thrive for years since. it propelled us into work we normally would never have achieved.
Feel free to call and come see the machine, we have all that was mentioned (Big DC, Vacuum, Scissor lift for panels) it is always a good idea to go see shops with machines, go see the plant where they are built. Camasters Tables are built Machined in The same town as Assembly it is a truly US built machine. feel free to join the forum and ask questions it has been a great resource for thousands I am really proud of it Joey Jarrard (us routertools) Josh Glenn (CNC genius) and I are the founders of camheads forum. we have kept the forum autonomus of the company using machine owners as moderators to keep all needed info out of the hands of salesmen, there is a lot there I hope you will take advantage of this resource. Feel free to check out my website (mcgrewwoodwork.com) or facebook (Mcgrew Woodwork) and peer thru the photos of the shop, work and cnc.
My machine is a 5 x 9 (I recommend a 5 foot width), there is nothing you cannot do with it as long as both ends and one side are open Mine has 15 tools (not needed but in my big 3d days was real handy) 7.5 hp spindle. I removed my beauty panels from the sides as cleaning is a bit#h under with them on we cut 40+ panels daily and a large amount of custom radius and 2.5 d parts
Good luck with your purchase, we have a policy to always mean well and warrant success for those who take these steps. it has been great for me and I pray that for you as well
https://camheads.org
3/15/22       #6: NEW CNC Recommendation for Mostly C ...
Stephen Williams
Website: http://partscuttercnc.com
FMT Patriot hands down.
I had one for 8 eight years, just a fantastic machine with an Fagor Controller.
If I didnt need the space I would have kept it. It served me very well and I was actually a little teary to see it go. FMT has lifetime support.
View higher quality, full size image (1080 X 1080)
3/16/22       #7: NEW CNC Recommendation for Mostly C ...
Bill Member
What is low volume. How many sheets a day or week do you predict?
3/17/22       #8: NEW CNC Recommendation for Mostly C ...
Have you included software in that budget? Tooling? Dust collection?
3/17/22       #9: NEW CNC Recommendation for Mostly C ...
Acctek  Member
The budget includes consumables and some accessories or shipping
8/2/22       #11: NEW CNC Recommendation for Mostly C ...
Rich Member
Thank you Everyone , I since then purchased a new Biesse Rover K 5x10 . Installation is happening next week. So much to learn.
    • Machinery Associates
    • Country Saw and Knife
