Morbidelli N100 & Mozaik
8/11/22
Michael
Is anyone running a morbidelli N100 with Maestro and Mozaik? Looking for some help on a post. Having difficulty with tool numbers between the two and not sure where to go at this point. Mozaik is 2 weeks out on getting me some help and SCM says it is a Mozaik problem.
8/15/22       #2: Morbidelli N100 & Mozaik ...
Have you got a working file that you can open in a text editor next to a Mosaik file? You could identify the tool number format differences and adjust your post processor to suit.
I'm sure you can find a guide to editing PPs online somewhere online or on the Mosaik website. Just make sure you keep a copy of the original so you can go back.
9/15/22       #3: Morbidelli N100 & Mozaik ...
Frank D. Jimenez  Member
Website: http://www.cabinetpro.com
Hi Michael,
Cabinet Pro software has a working post for your Morbidelli N100. I've copied the code for that post below so that you may give it to Mozaik to perhaps speed up their creation of your post processor. The code that follows will drill holes of different diameters and cut out the part shown in the picture below. Both the picture and the code were processed in Cabinet Pro software, but Mozaik is welcome to use the code as a template if it will get you your post quicker. The tool number is easily defined as "T=102" and then "T=103" for routing, as you can see near the bottom of the code. (The Spindle Speed is defined there as well.)
Morbidelli Code that will machine the part shown in the picture below:
H DX=96.9291 DY=48.8583 DZ=0.748 BX=0 BY=0 BZ=0 -AD C=0 T=0 R=1 *IN/"DEF"
PLOAD I=0 Q=0# R=1# a=0 r=4.0# s=0 G=0# L=0 B=0
SET ZFAST = -0.375
F=1
BO X=9.6793 Y=46.5053 Z=0.4921 V=5080 D=0.19685 N="P"
BO X=12.199 Y=46.5053 Z=0.4921 V=5080 D=0.19685 N="P"
BO X=14.7187 Y=46.5053 Z=0.4921 V=5080 D=0.19685 N="P"
BO X=9.6793 Y=30.1086 Z=0.4921 V=5080 D=0.19685 N="P"
BO X=12.199 Y=30.1086 Z=0.4921 V=5080 D=0.19685 N="P"
BO X=14.7187 Y=30.1086 Z=0.4921 V=5080 D=0.19685 N="P"
BO X=0.571 Y=47.4014 Z=0.4921 V=5080 D=0.31496 N="P"
BO X=0.571 Y=42.5195 Z=0.4921 V=5080 D=0.31496 N="P"
BO X=0.571 Y=37.6376 Z=0.4921 V=5080 D=0.31496 N="P"
BO X=0.571 Y=32.7558 Z=0.4921 V=5080 D=0.31496 N="P"
BO X=0.571 Y=27.8739 Z=0.4921 V=5080 D=0.31496 N="P"
BO X=29.8112 Y=43.6219 Z=0.4921 V=5080 D=0.31496 N="P"
BO X=29.8112 Y=47.4014 Z=0.4921 V=5080 D=0.31496 N="P"
BO X=29.8112 Y=29.9408 Z=0.4921 V=5080 D=0.31496 N="P"
BO X=29.8112 Y=26.1613 Z=0.4921 V=5080 D=0.31496 N="P"
BO X=23.945 Y=47.3621 Z=0.4921 V=5080 D=0.31496 N="P"
BO X=23.945 Y=43.5825 Z=0.4921 V=5080 D=0.31496 N="P"
G0 X=0.0789 Y=25.5727 Z=-0.375 V=6000 T=102 S=18000
G1 Z=0.2362
G1 X=30.3033 Y=25.5727 Z=0.2362 V=10160
G1 X=30.3033 Y=25.5294 Z=0.2362 V=10160
G1 X=0.0789 Y=25.5294 Z=0.2362 V=10160
G0 X=30.3727 Y=48.8488 Z=-0.375 V=6000 T=103 S=18000
G1 Z=0.7559
G1 X=0.0095 Y=48.8488 Z=0.7559 V=10160
G1 X=0.0095 Y=24.7139 Z=0.7559 V=10160
G1 X=30.3727 Y=24.7139 Z=0.7559 V=10160
G1 X=30.3727 Y=48.8488 Z=0.7559 V=10160
PUNLOAD A=DX
.EOF
View higher quality, full size image (1921 X 1079)
    • Machinery Associates
