What do you use as a topcoat?
9/19/22
Michael Member
Website: https://wattsan.com
Hello friends!
I am not so long working with wood. Here I tried to make an interesting layout. That's what I got. Now I want to give it to my cousin. Can you advise what kind of oil is better to cover, to make the product a little darker ( walnut color).
View higher quality, full size image (1280 X 1280)
https://wattsan.com/products/cnc-routers/
9/19/22       #2: What do you use as a topcoat? ...
Are you a salesman for watts? Curious why you post a question about finishing in a CNC section. Professional Finishing forum will get you more responses. I would suggest a dye, glaze, then a flat sheen lacquer.
9/20/22       #3: What do you use as a topcoat? ...
Ian
walrus oil and linseed
9/26/22       #4: What do you use as a topcoat? ...
Michael Member
Website: https://wattsan.com/
No, I'm not. I just demonstrate on which machine it was made, if, of course, it is interesting to someone. well, I recommend them, because I work with them myself for a long time.
9/26/22       #5: What do you use as a topcoat? ...
Michael Member
Thank you
Ian
9/26/22       #6: What do you use as a topcoat? ...
Just thought it was peculiar to post the machine you support on a question about finishing.
11/3/22       #7: What do you use as a topcoat? ...
Erick Member
Website: https://virmer.com/
Try walrus oil
    • Machinery Associates
