What cutters do I need for milling beech?
8/31/22
Adea00Leka Member
Website: https://virmer.com/
If you take a V-shaped taper milling cutter, it will not be possible to remove much at the 1.5 kW spindle, as this cutter will have a large area of contact with the material. This makes it difficult to penetrate the beech on this spindle with this cutter.
You need a lot of torque and a more powerful spindle.
What if I am into 3D engraving (this applies to engraving on any material)? Then what are the most suitable cutters, a form like a carrot?
8/31/22       #2: What cutters do I need for milling ...
Matthew Madigan Member
I've been doing some carvings lately and these bits have been great.
https://www.toolstoday.com/v-14204-ams-148-k.html?glCountry=US&glCur
rency=USD&ne_ppc_id=17661103801&gclid=Cj0KCQjwjbyYBhCdARIsAArC6LLuZ7ySgPp
0D4fzxyLeAe3KOnEDIFya9AAV0SUD8BBp2YK6WdGs65gaAlqREALw_wcB
Definitely want to use roughing bits to get as close as possible but these do a great job on the finish.
9/20/22       #3: What cutters do I need for milling ...
Ian
tapered ball nose
9/26/22       #4: What cutters do I need for milling ...
Adea00Leka Member
@Matthew Madigan
I'm glad I could help.
    • Machinery Associates
