Saw feeds and speeds for solid wood and sheet stock
12/7/22
Mark
I have a 5 axis Biesse rover and would like to do sawing operations in solid wood and sheet stock. With the machine came a 300mm 24 tooth blade, 3.2mm kerf in an HSK63F tool holder.
Can anyone suggest a proper feed and speed rate for this tool, or comment on other saw tooling you have had success with? I am pretty familiar with feeds and speeds for typical router bits, but have little experience with saw blades. Is there a suggested chip load I should start experimenting with?
12/8/22       #2: Saw feeds and speeds for solid wood ...
Marek  Member
Website: http://www.cadcam-softcz.cz
Hi, you can try spindle speed 3500 - 4000 rpm. Feed about 6-8 m/min.
12/8/22       #3: Saw feeds and speeds for solid wood ...
Mark
Thanks Marek, just what I was looking for. I will give it a try,
12/12/22       #4: Saw feeds and speeds for solid wood ...
Dylan Bayliss
Please find below. Guide for other materials and chiploads
db
View higher quality, full size image (706 X 835)
12/13/22       #5: Saw feeds and speeds for solid wood ...
Mark
Dylan,
Thanks that is some good detail, very useful. I will keep it on hand.
Malik's numbers check out with the chart too.
Mark
7/6/23       #6: Saw feeds and speeds for solid wood ...
drewbinsky
Website: https://ovo-game.com
It's important to take into account a few variables when choosing the feed and speed rates for sawing operations with a Biesse Rover machine, including the material you're cutting, the particular saw blade you're using, and the desired cut quality.
