Syntec 6MB tool tip measure and Z Delta Set have never worked
9/16/22
Anton  Member
Hi,
I purchased a syntec 6 MB machine from China in late 2019. While the controller offers the options of " Tool Tip Measure" and "Z Delta Set" as an easy way to calibrating material top Z height (using T1 as a reference) for an entire tool set, this has never functioned on my machine. The feature is like a book cover without a book.
While I get away with not using the above by making use of manually incrementing tool sensor values referencing T1 (in other words, incremented, T1 becomes 0), assuredly Z Delta Set would save some time.
Has anyone here experienced this, and how was it rectified?
12/18/22       #2: Syntec 6MB tool tip measure and Z D ...
Javito Member
https://www.cnclathing.com/guide/types-of-cutter-compensation-tool-length-cutter-r
adius-compensation-definition-and-g-code
In order to take advantage of z delta your Gcode needs to use the tool length compensation
    • Machinery Associates
