Need to laminate and trim large volume of legs 2.3125 x 2.3125 x 32"
12/17/22
Rich  Member
I need to find a machine that can apply and trim HPL to a square leg that is 2 5/16" x 2 5/16" x 32" long. Anybody know of a machine that can do this or a company that would modify an existing machine to do it. We do over 1000/month and laminating and trimming by hand on shaper is very time consuming.
Thinking a small bander with a tall glue pot might work but would need to pull trimming stations up against the belt. Have not found a small bander that has tall enough glue system. Tried on our regular bander but to much overhang on belt and parts dont stay square to stations.
12/18/22       #2: Need to laminate and trim large vol ...
james e mcgrew  Member
Buy or layup thickness on a sheet good 2 sides. cut lengths to width less plam thickness, (if you have a cnc) you coule build a jig palcing unfinished ends up set .26 wide, laminate this entire sheet side in jig and trim, flip parts and do the other side. then cut to length, My hope is you are not doing all short pieces each time
12/20/22       #3: Need to laminate and trim large vol ...
Rich  Member
We do the following.
layup panel with laminate two sides. (PVA white glue in pod press)
Cut to size
Cut slightly oversize strips of HPL for last two sides.
Back to glue press to apply HPL to last two sides.
to shaper to trim and bevel.
Was hoping to get a recommendation on a machine that could apply and trim last two edges.
12/21/22       #4: Need to laminate and trim large vol ...
Robin Smith
The specs on our Holzher Sprint indicate a maximum panel thickness of 60mm which may just work for you. I have not physically tried to feed anything through there beyond 2" however, so can't say for sure it would work.
12/21/22       #5: Need to laminate and trim large vol ...
What about mitre folding the leg?
Regarding the edgebander - when you say not square do you mean it's moving away from the trimmers or drooping? If moving away from the trimmers you could put a fence that prevents the part from moving away from the trim stations. Just a series of strategically placed rollers would do. The stations float so just need to get close.
If drooping make the parts 2 wide plus a saw kerf. Edgeband the outside edges, split on a saw and then you only need to do 1 edge per part manually.
