I want a clearer edge. What I do wrong?
1/26/23
Rudolf  Member
Website: wattsan.com/
Here’s my work. I did it on a Wattsan M1 6090. Material: 40mm beech. But for some reason the edges are not as sharp as I wanted them to be. Who knows what could be the reason? Maybe the material is wrong?
View higher quality, full size image (1280 X 1280)
https://wattsan.com/product/wattsan-m1-6090/
1/28/23       #2: I want a clearer edge. What I do wr ...
Karel
Hello,
The machine should do what you want. Is this code from a solid model you created yourself? Try use a smaller finishing cutter with a smaller step over distance. This type of work just takes a long time to run nothing to do about that.
Happy cutting
Karel
1/30/23       #3: I want a clearer edge. What I do wr ...
Will Williamson  Member
You would be better off to post the question on The Vectric forum this site has mostly industrial CNC users. https://forum.vectric.com/viewforum.php?f=27&sid=a558986ac1b110b964546428bb239
579
1/31/23       #4: I want a clearer edge. What I do wr ...
MichaelWWi Member
Website: https://virmer.com/
Karel, Great advice! I think I'll take it to myself, because I also faced with this problem.
    • Country Saw & Knife
    • Charles G.G. Schmidt Co.
    • Biesse America
