Large custom knife for 5"Tx3"D arched heavy crown moulding? Laguna SSII SUV
4/21/23
Tkottke Member
We are looking to quote a job that has a very large profile to cut in an arch. We have a Laguna SSII SUV CNC that should have the height I need. I need to know what the limits are of custom knife profiles when it comes to machining tall profiles.
Also, who would you recommend getting this custom cutter from?
4/21/23       #2: Large custom knife for 5"Tx3&q ...
Is this a one off job? You will likely spend something on the order of $1K or more on the custom cutter head. Unless you are doing a thousand feet or so you would be better off routing the moulding with a two rail sweep and a bullnose bit. There will be hand sanding and it will take longer.
4/22/23       #3: Large custom knife for 5"Tx3&q ...
BH Davis  Member
Unless you have a 5-axis machine so you can run with the cutter head axis parallel to the face of the moulding I'd strongly advise against doing this with a single knife. I wouldn't want to be in the same building, much less the same room, when a knife that deep was spinning.
You would be much better off to split the moulding into upper and lower halves, profile each half independently and then glue the two layers together.
Plus, I'd also ask how you are making up the blank. If you are not doing a brick laid construction, but rather just cutting a mild arc out of a single wide board, you are going to run into serious end grain on one end of the blank. This too can raise concerns with both tear out and resultant knife breakage. All becomes less safe of course with a dangerously deep set of knives.
4/23/23       #4: Large custom knife for 5"Tx3&q ...
Are you looking for a shaper cutter head that will hold your own corrugated knife steel? I have cuts many profiles on hardwood using these knife holders. Mine have a 3/4" shank and have been worth their weight in gold over the years. I will post a picture of the body. It will also accept steel longer than the body. Sometimes it takes two of these cutters if the moulding is that large. I could provide an example if you are interested in the holder.
View higher quality, full size image (1008 X 756)
4/24/23       #5: Large custom knife for 5"Tx3&q ...
Okay, now that I'm back at work, I was able to take a picture of the moulding I was referring to in the sample room.
4/25/23       #6: Large custom knife for 5"Tx3&q ...
That can be cut on an arch molder. If it is a one off it does not make sense.
For a sanity check I would have art for every day quote it.
4/25/23       #7: Large custom knife for 5"Tx3&q ...
BH had a good point. I recently did some rift cut walnut crown. Since you can't buy rift in walnut, we had to bricklay the pieces. It was 9.75" tall. We made two pieces and glued them together. Came out beautiful. That crown was all done with ball end mills and flat tools. Took a long time on the machine, but minimal sanding was required before finish. It was for a casino, so they had the money and it was very profitable.
4/26/23       #8: Large custom knife for 5"Tx3&q ...
I would do as BH suggested. Bricklayed and in three separate moulding knives. Top portion with the ogee and bead, mid ovolo, lower cove. Do the lower cove with a moulding toolpath and ballnose bits. The other sections cannot be done this way because of undercuts.
4/26/23       #9: Large custom knife for 5"Tx3&q ...
Back to the original poster. I am still not sure what the heck he is looking for. Can you post the profile so we can try to answer adequately?
4/27/23       #10: Large custom knife for 5"Tx3&q ...
Tkottke Member
I want to thank everyone for their input/experiences on this topic. For my specific situation, I think I can pre-cut the "layers" and make glue up and finish with a ball mill as it is a tall, sweeping cove I need to create, not an intricate shape.
All the responses were beneficial.
Thanks!
    • Country Saw & Knife
    • Charles G.G. Schmidt Co.
    • Biesse America
