holzer conquest cnc with NUM CONTROLS
5/3/23
Rodney blackerby Member
looking at a used machine that has been out of service for about a year unhooked from power, I was told the battery can die if this happens you will have to have the parameter files to re load. i dont want to buy a ship anchor.lol anyone had any experience with this?
5/3/23       #2: holzer conquest cnc with NUM CONTRO ...
Don't know this particular machine or control but been there done that more than once.
Contact Holzer with the serial number and see if they have the backup files. Also check if the parameters are stored in non-volatile memory somewhere in the control. I had a couple of Biesse Arrow's with OSAI controls that had dead batteries when I bought them but the parameters were available on the control.
If possible connect power and see if the machine comes to life. If so, replace the battery while it's under power. If not, and you can get the files, adjust price accordingly.
If you can't hook up power or it won't come to life and you can't get access to the files from Holzer move on to the next deal.
5/4/23       #3: holzer conquest cnc with NUM CONTRO ...
Yes, batteries need to be changed yearly. Main thing is if you want to replace batteries, do it with the machine powered up. Not sure what parameters the batteries are backing up on this particular machine, but it can be a concern. On my current machine, batteries back up home position of two rotary axes, 4 linear axes and the tool changer. That is all they do. Not the end of the world if one of the batteries dies and someone shuts off the machine, but it takes a chunk out of my day to re-home. Reloading machine parameters is not terrible either, but you need a good backup. As Dropout said, contact Holzher and see what you can find out about this machine including availability of parts that are wear items.
6/18/23       #4: holzer conquest cnc with NUM CONTRO ...
Ian
Our pro master came with all of the backup CDs, see if he has them. Should be in a binder in the control cabinet
    • Machinery Associates
    • Country Saw and Knife
