Anderson Selexx Eco
8/6/23
Harry Member
Hello there team
We just bought Selexx Eco few months back, been quite a journey setting it up. Learnt many new things as we are new to CNC world.
Tool #3 is stuck in the spindle, tried almost everything but no luck.
Also if there is anyway we can buy or D/L operating manual with how to clear out the error codes.
Any help would be much appreciated.
We are located in Sydney Australia.
Thanks and regards.
8/8/23       #2: Anderson Selexx Eco ...
You should be able to get a manual from Anderson America. They've been good to us and we're in Canada.
There should be something on the spindle to let you drop the tool out. If there is and you hear the click but the tool won't come out tap it sideways very very gently. Tapers can stick if left too long.
If you cannot hear a click, turn everything off including the air, disconnect the air lines from the spindle and try blowing compressed air into the fitting.
BE CAREFUL.
I always put a box of rags under the tool so I don't break anything when it drops. I prefer not to be holding a sharp bit when it kicks out.
8/13/23       #3: Anderson Selexx Eco ...
Justin Morris Member
To get your tool to release manually, the machine must be in rapid or jog mode via the dial selector. Once the machine is in jog or rapid, press the button on the spindle to release the tool.
Anderson America information repository is in the link below.
https://andersonamerica.stonly.com/kb/en
    • Better Vacuum Cups, Inc.
    • Limtech Industries, Inc.
