Anderson Agmvp
7/28/23
Nathan
Is there anyone on the forum familiar with Andersons AGMVP interface. Im having some issues with setting the G55 z offset for the MultiDrill. Tried setting it manually by jogging the drills to the spoilboard and inputting the z value into the G55 Z offset (this was the way I used to do it in my omnitech) but its out by more the 1/2 inch. Im wondering if they changed the way the z offset is calculate and if theres a diffrent way to measure the drills throught the new interface.
Nathan
8/8/23       #3: Anderson Agmvp ...
Matt Hicks  Member
Website: http://www.andersonamerica.com
Nathan,
When doing the manual drill touch off, activate the #1 drill and bring it down to the top of the spoilboard. Then on the g55 work offset in agmvp highlight the z value and press the measure button. That should input the z value for the machine coordinate.
If that does not work then check the z depth for the drilling operations in the program.
Hope this helps.
Thank you,
Matt Hicks
8/8/23       #4: Anderson Agmvp ...
Nathan Member
Thank you Matt. I will give this a shot..
Nathan
    • Machinery Associates
    • Country Saw and Knife
