What are you using to program your Biesse Rover
8/14/23
Wleach Member
Curious as to how many folks are using something other than bSolid to program for 5-axis machining. If you use the Biesse software you know how weird it can be. Looking for input on MasterCAM and HSM, but open to other options
8/14/23       #2: What are you using to program your ...
Justin Morris  Member
Website: https://www.centexautomation.net/
The customers I have seen with a Biesse 5-axis use Mosaic, CabinetVision, MasterCam, etc. But yes, bSolid is a nightmare to program with, unless you use that day in and day out.
8/15/23       #3: What are you using to program your ...
Dylan Bayliss  Member
Website: http://www.machineconsult.com
reach out to me as I have a contact that has used all three, MasterC,AlphaC, and Bsolid. Happy to share his number, as he is now an freelance programming consultant.
Dylan
314-504-8098 c
www.cnc-tool.com
8/16/23       #4: What are you using to program your ...
Erick Member
Website: https://virmer.com
Another option is HSM (High-Speed Machining). HSM is characterized by fast and efficient 5-axis machining programming.
https://virmer.com/catalog/cnc-milling-machines/
