cutter not exiting nested pocketing
10/31/23
Website: http://cabinetree.ca
We are running nested shaker doors on a Biesse RoverB using Cabinet Vision 2022. The nested parts all run as expected except for the pocket of the door panel. The cutter does not do a lead out at the end of the individual door pockets but simply treats it as a single milling and moves to the next door in the operating position resulting in a cut through the door rail/stile. Has anyone else had this issue?
Thank you
11/1/23 #2: cutter not exiting nested pocketing ...
Does CV have simulation?
If so, what does that look like?
11/1/23 #3: cutter not exiting nested pocketing ...
yes, the simulation in CV acts correctly, leading out and back into the individual doors. It is when the program optimizes on the Biesse Rover that the program end command disappears and the milling becomes one uniform program.
11/1/23 #4: cutter not exiting nested pocketing ...
Ouch.
Sorry can`t help with that. All my Biesses were G Code or we programmed at the machine.
Any way of turning the optimizing off?
11/1/23 #5: cutter not exiting nested pocketing ...
no, unfortunately it has to optimize at the machine.
