Pod and rail issues with warping on solid wood panels
11/14/23
Julian Fischli
Just wondering if anyone knows how much of an issue warped solid wood panels would be on a pod and rail CNC. is the vaccuum enough to hold a warped panel down or flatten it ?
11/14/23       #3: Pod and rail issues with warping on ...
How may pods?
How warped? How thick?
What species?
Drilling or cutting?
What HP pump?
11/14/23       #4: Pod and rail issues with warping on ...
Julian Fischli
19mm solid birch panels, 360x1300mm, on 6 pods. this would be for drilling and routing/ profiling. the pump is a Busch, 360m3/h claw pump.
11/14/23       #5: Pod and rail issues with warping on ...
I'd try it.
11/15/23       #6: Pod and rail issues with warping on ...
Mike McClaran
Website: http://www.bettervacuumcups.com
You will have to press down on the middle of the panel to get the 2 middle cups to hold. Once the middle cups make a seal it should be no problem to hold it flat. It would be even easier with one cup on each corner but then you have warp and vibration in the middle. Let me know how it goes because we can help with a Better Vacuum Cup.
11/28/23       #7: Pod and rail issues with warping on ...
Ian
I would prefer 8 pods if available
