1/2 inch compression Vs 3/4 inch melamine Burning
11/20/23
Hello Everyone,
First time posting on here but have a dilemma. I have 2 SCM n100 CNC's and 1 Homag N700 CNC. We typically run a 1/2 inch compression as our main cutting tool through 3/4 inch melamine. Feed is 25 meters/min spindle speed is 18k RPM. (.018 Chipload). We have ran this setup for a couple years averaging 80 to 120 sheets of material per bit. Within the last 2 months we started burning out our bits and chipping material around 20 sheets. Manufacturer said there has not been any changes to the core of the melamine but i highly doubt that's the case as its happening on all 3 machines. Any insight or is anyone else having issues at this time?
11/20/23 #2: 1/2 inch compression Vs 3/4 inch me ...
Anytime I have that issue, its always an issue with the board manufacturer. Try another vendor for a time.
11/20/23 #3: 1/2 inch compression Vs 3/4 inch me ...
There must be some bad board going around. I have heard this
same problem 2-3 times in the last week.
11/21/23 #4: 1/2 inch compression Vs 3/4 inch me ...
Website: http://www.casadeibusellato.us
Has to be the board, we have a customer experience this very same thing. Board supplier confirmed bad board and replaced entire unit.
11/22/23 #5: 1/2 inch compression Vs 3/4 inch me ...
Website: http://www.machineconsult.com
My customer said Egger had known issue will resolve if notified
www.cnc-tool.com
11/27/23 #6: 1/2 inch compression Vs 3/4 inch me ...
Thanks for all of the responses, it was bad board. Manufacturer had put too thick of a coat of white melemnine.
