TOOL RACK ON A PRATIX N 15
11/22/23
rodney Member
I was wondering if some has or uses one of these machines it runs on xilog/ kavra software trying to adjust the tool height setting to get the tools to line up with the rack, every aligns perfect but the spindal drops down to far and trys to bend the rack down, its a side mounted tool holder. i would think there would be some parameter adjustments that can be made just not sure how to do this. Any help would be greatly appreciated.
11/25/23       #2: TOOL RACK ON A PRATIX N 15 ...
Did your machine just start doing this? There is a photo cel that needs to be kept very clean otherwise it doesn’t see the tool entering the tool holder properly.
I would give SCM a call, if you can’t figure it out, they have great tech service, a tech can log right on to your machine and check for issues. It costs a bit to get set up with Teamviewer though.
    • Better Vacuum Cups, Inc.
    • Charles G.G. Schmidt Co.
