Bamboo plywood chip load
11/27/23
Nicholas Crobaugh Member
Hey all,
Looking for any advice on CNC milling of bamboo plwoods. Particularly pertaining to chip load and what bits you are using. I'll be running 1-4"-3/4" thicknesses and cutting for case parts as well as doors of the cabinetry.
Plan currently is to run the outline tool as 3/8" compression bit and make the cut in 2 passes limiting the cut depth to 3/8". Rest of the operations will likely pull from 1/4" comp/downshear for grain matching and any dado/groove cuts. Pocketing operations jumping up to 1/2" downshear.
Any help or experience is appreciated.
All the best,
Nick
11/30/23       #2: Bamboo plywood chip load ...
Can you confirm the thickness of the plywood?
12/3/23       #3: Bamboo plywood chip load ...
mike
Chuck,
Figure on 3/4". He said .250-.75 but I have 3/4" in house
12/4/23       #4: Bamboo plywood chip load ...
A lot going to depend on the machine size and capabilities.
Normally, 18,000 RPM 800 to 900 IPM to start, full depth. I would recommend 3/8 2+2 Mortise Compression w/chipbreakers since you are. cutting plywood.
**Always make sure collets have been changed or are in good shape.
12/4/23       #5: Bamboo plywood chip load ...
Sorry for my delay on this and thank you for the input.
Machine is a Camaster Cobra Elite CR-612
18000 RPM
400IPM
So far the test cabinet went together beautifully. Cross cutting on the plywood was prone to lifting fibers but a quick pass with a sanding block cleaned it up well. We'll be experimenting with different bits to see if possible to eliminate this.
    • Machinery Associates
    • Country Saw and Knife
