Vacuum lifter replacement lift tube? Sources?
12/29/23
Matt Member
Our Piab vacuum lifter has a Lift Tube replacement size that is 180mm x 2.5m and we use it for lifting sheetgoods up to 300lbs. Rarely do we do anything heavier than 5x10 3/4" MDF but we have occasionally lifted 1.5" thick 5x10 butcher block.
$1800 for the OEM lift tube, with price increases supposedly hitting January 1st, is a bit much for this it seems to me, does anyone have a source for such things?
I know how to buy dust collector hose but this lifter hose is a very different critter is seems.
1/2/24       #3: Vacuum lifter replacement lift tube ...
Find a place that sells hose for vacuum trucks. That's where I buy all my large hose. Dust collection hose may collapse at full vacuum.
1/2/24       #4: Vacuum lifter replacement lift tube ...
Matt Member
That's an idea. Thanks!
1/3/24       #5: Vacuum lifter replacement lift tube ...
MC
maybe give this place a shot.
i have used for similar type products.
Air Handling Systems
https://airhand.com/
good luck
mike
    • Machinery Associates
    • Country Saw and Knife
