Cnc research
12/7/23
Kev
Hi in in the market for a cnc router
5 axis flat table for 40%nesting 60% hardwood machining
I'm looking at holzher
And Homag which is the better one??
12/7/23       #2: Cnc research ...
I'm kind of biased because I have two of them. One is over 20 years old and one is 2 years old. Take a look at Northwood Machine. They just get better and better. I'd put them up against anybody for reliability, service, and support. I've had European machines in the past. They will stay in my past. Good luck!
12/7/23       #3: Cnc research ...
Why do you want a 5 axis for nesting? You will be carving the hardwood? Better price your software before buying a 5 axis machine.
12/7/23       #4: Cnc research ...
Kev
The reason I want 5 axis with flat table is that I can do both with just one machine nesting and carving or machining hardwood raised on pods like doors or stairs railing or table legs ect..
12/8/23       #6: Cnc research ...
BH Davis  Member
You don't need a 5-axis machine for door edges etc. You just put an aggregate head on the spindle and you can come in from any direction except upward.
You will need some sort of pod hold down system in addition to the spoil board though. I'd suggest some more research on your options.
1/29/24       #7: Cnc research ...
Michael Member
Website: https://wattsan.com
Both Holzher and Homag are reputable manufacturers of CNC routers, and both have extensive experience in providing quality equipment for woodworking applications. Deciding which one is better for your specific needs will depend on several factors such as the specific models being considered, your budget, and the level of support and service offered in your area.
11/18/24       #8: Cnc research ...
ThomasRoan Member
It depends on the budget, requirements, and level of proficiency in operation.
    • Limtech Industries, Inc.
