Another cnc transformer question
3/1/24
Dave Edgerton  Member
So this holzher cnc needs 400 volts 3ph we have 230v 3ph.
what kind of transformer will work? dleta-delta or delta-wye?
any suggestions on manufacturer would be helpful. holzher is exteremly slow to reply.
3/2/24       #2: Another cnc transformer question ...
I would consult with a qualified Electrician. A woodworking web board is not the place to look for information like that.
3/4/24       #3: Another cnc transformer question ...
Rob Young Member
Dave- Along with the 400 volts do you also need a neutral? If so you need a Delta Wye transformer.
3/4/24       #4: Another cnc transformer question ...
Thank rob, that was what i was supecting.
3/8/24       #5: Another cnc transformer question ...
Confirmed by our electrician. Dleta-wye isolation transformer
4/10/24       #6: Another cnc transformer question ...
Erick Member
Website: https://wattsan.com/
You'll need a delta-wye transformer to step up the voltage from 230V to 400V. As for manufacturers, some reputable options include Siemens, ABB, or Schneider Electric.
    • Better Vacuum Cups, Inc.
    • Charles G.G. Schmidt Co.
