CNC machine for engraving on plywood / acrylic sheet
2/14/24
cheriLongsworth Member
Website: http://.
(you can check their config here https://www.cncrouter-shop.com/pro/c...aving-machine/)
A friend of mine suggested to get wattsan 1610 LT, they're a little bit larger so I thought maybe we could buy less machines then.
(you can check their config here https://virmer.com/catalog/laser-machines/wattsan-1610-lt/).
Our firm primarily focuses on creating boxes for different occasions with various engravings (for bday presents mostly). Sometimes there are offers for pretty large boxes and those ELE1390 couldn't help it.
Maybe there are other options, these are the ones I encountered so far.
Thanks for help in advance.
2/14/24       #2: CNC machine for engraving on plywoo ...
Every cnc router will engrave on plywood and acrylic. There are thousands to choose from, but you are asking on a professional woodworking forum where 5'x10' machines with automatic tool changers are the standard discussion. The bit choice is the critical item.
4/10/24       #3: CNC machine for engraving on plywoo ...
Erick Member
Website: https://virmer.com/
As far as I know LT has a lifting table, are you sure you have to pay more for that function?
    • Machinery Associates
