Schelling FI 430. Memory card or battery?
4/17/24
IGOR Member
Hi all. I am sorry for my English. I use Google translator. A frequency converter was repaired on a format-cutting machine Schelling FI 430. Because of this, the machine was turned off for 3-4 months. After repair, when you turn on the operator panel, the message "Memory card, battery, exchange" appears. You can't work while doing this. After 1-2 hours the message will disappear and you can work. If you turn off the machine, the situation will repeat. I'm guessing it's the battery, but they couldn't find it in the control panel. Tell me what the problem might be and where to look for the cause. THANK YOU
View higher quality, full size image (1600 X 900)
4/17/24       #3: Schelling FI 430. Memory card or ba ...
IGOR  Member
Additional photos:
4/17/24       #4: Schelling FI 430. Memory card or ba ...
BH Davis  Member
I really can't help with the specific machine but motherboards in general use a 2032 battery. Look for a thin, round battery like the one in the photo somewhere on the control board(s).
4/18/24       #5: Schelling FI 430. Memory card or ba ...
One of my Biesse Arrows had the battery in one of the pre-programmed memory chips.
That was really annoying.
4/19/24       #6: Schelling FI 430. Memory card or ba ...
Erick Member
Website: https://virmer.com/
It sounds like the issue may indeed be related to the battery on the control panel, which could be failing or in need of replacement after the extended period of the machine being turned off.
