holzher cnc machine vs biesse
5/1/24
KIM DANG Member
Hi
Any ideas about the cnc BIesse vs Holzher?
I cannot decide which one after comparing pros and cons of the 2 brands
plz share your thoughts
many thanks
kim
5/2/24       #2: holzher cnc machine vs biesse ...
Whichever one does not have proprietary software.
5/6/24       #3: holzher cnc machine vs biesse ...
cheriLongsworth Member
Website: https://virmer.com/catalog/cnc-milling-machines/
Biesse has more functions and modern technologies, Holzher is more precise and reliable. Depends on what you're looking for, what type of project you run
5/7/24       #4: holzher cnc machine vs biesse ...
krepco Member
I have been running a Biesse Rover B 5 axis for 6 years, precise, reliable and a workhorse. A few minor issues that any machine will have but service was stellar, parts department knowledgeable and fast. bSolid is proprietary and has been a huge addition to the other software I have, CV, enroute and sketchup. Highly recommend!!!
5/12/24       #5: holzher cnc machine vs biesse ...
Jim Herron
I ran a Weeke pod and rail for several years until it caught fire.
I bought a used Biesse A3 to replace it.
After an initial frustration with the Biesse, mainly due to learning the new software, the Biesse is hands down more flexible and much faster.
I think the technology advanced a lot in the age between the two machines.
Build quality of both is top notch and I think you can be confident in either.
5/13/24       #6: holzher cnc machine vs biesse ...
Jim Herron
Sorry. I commented on the Weeke cnc
Only experience I have with HolzHer is with their edgebanders.
That said, I wouldn't consider another brand edgebander
5/17/24       #7: holzher cnc machine vs biesse ...
Ryan
We have been running Biesse routers for 11 years and love them. We had a Weeke prior to that with all sorts of troubles. We looked at a Holzher CNC the last time we purchased one in 2020 but the features don't compare to the Biesse. We do run a Holzher bander and that is the only Holzher equipment I would reccomend.
Biesse has great customer service and we have had great success with them.
6/3/24       #8: holzher cnc machine vs biesse ...
Robert Jacobson Member
We purchased a Biesse CNC 2 years ago. The installation was less than ideal, and we requested another person come in and fix it after a lot of threats/begging, etc. We are having problems with the valve piston (pointed up) snagging the flex dust collection hose. Here is the response after the sale from a regional "service manager":
"As for the issues your having, these fall under the buyers responsibility. Biesse does not handle any of the dust collection. This is the responsibility of the customer (you). You should have had a dust collection company come to install the piping if you were not sure on the proper lengths and such. If I remember correctly, you had your own employees hanging the dust pipe.
As Tom mentioned, this will not be able to be covered under warranty in any way."
FYI... We did hire a dust collection company to design and fabricate our parts for this system. It turns out that the flex pipe stretches over time and we shortened it. It took going back to the original salesperson to get this recommendation.
6/5/24       #9: holzher cnc machine vs biesse ...
Pavel
Hi, I can give you a view from the programming side. If you want to made programs on the machine, the bSolid (Biesse) is better than NC hops (Holzer).
In the case that you has external CAM (for example Alphacam) the NC hops i more easy connectable than bSolid because the structure of the code is simplify.
For example fully 5-axis movements are not visible inside the bSolid - in the simulation with the machine it is visible.
NC hops can have Vector milling for 5-axis which allow you to see all movements inside the simulation.
Generally connectable are both machines.
7/19/24       #10: holzher cnc machine vs biesse ...
Yaakov katz Member
Can't even start compre
Biesse 10 level above
First biesse do cnc for 50years
Biesse develop all there software,holzer only buy like Chinese and install,I don't see any small options to compare
    • Better Vacuum Cups, Inc.
    • Limtech Industries, Inc.
