morbidelli 425 pp
6/2/24
Hamza
Hello
I have a scm morbidelli author 425
Does anyone have post processor for the alphacam
6/4/24       #2: morbidelli 425 pp ...
If you can't find one, Google Pavel Vintr. He probably has something close.
6/5/24       #3: morbidelli 425 pp ...
Pavel
Hi, I can help you with it. I had done many posts for the SCM/Morbidelli, based on XIlog or Maestro.
If you want, contact me.
Thank you.
Pavel
7/4/24       #4: morbidelli 425 pp ...
Mike Member
Website: https://virmer.com/
The Milwaukee M18 right angle drill you mentioned only provides 125 in-lbs of torque, which is much less powerful than the 125 ft-lbs needed for your application. For drilling 2-3" grommet holes, the lighter drill likely won't have the necessary power. Stick with the beast of a right angle drill you initially bought for reliable performance.
    • Better Vacuum Cups, Inc.
    • Limtech Industries, Inc.
