Drill Bank Operation
10/10/23
AJ Bacik
My shop runs an Omnitech Selexx PAL. we have a drill bank and no idea how to use it. any manual had long since been lost and I can find nothing online. Would anybody be able to point me in the right direction in finding a manual or how to video, anything? Thank you in advance.
10/11/23       #2: Drill Bank Operation ...
John G
What are you using for software?
The drill bank works off of the G55 work offset.
From my understanding they made several different drill bank configurations. All the M and B codes and configuration should be done in you S2M software
10/11/23       #3: Drill Bank Operation ...
AJ Bacik
THAT is a fantastic question. I have no clue. I'm very new to the CNC game. So, to be honest...I have no idea what any of that means right now. But I will have to find out.
As for what software we use, are you asking what program we use to write cnc files? or are you asking about which software runs the cnc machine itself?
10/11/23       #4: Drill Bank Operation ...
John G
Yes. What is the program writing the CNC files? You should have a Fanuc I/O controller.
G55 tells the machine where the drill block is in relation to the spindle
Check out this article for a little bit of background of G code.
https://howtomechatronics.com/tutorials/g-code-explained-list-of-most-important-g-
code-commands/
Not everything here translates 100% to your machine, but it helped me understand a lot of the ins and out, and why we would encounter certain problems when I was just starting out.
10/11/23       #5: Drill Bank Operation ...
AJ Bacik
Thank you for the link, I will definitely check it out. As for the program, we use Enroute. I'm told we've never had cause to use to drill bank, but were looking into how in case the occasion arises.
10/11/23       #6: Drill Bank Operation ...
John G
I would contact Enroute about getting the proper training and post processor so move forward
10/12/23       #7: Drill Bank Operation ...
Jim Anderson
In EnRoute, under machine setup / driver you have to select "Has Drill" then setup your drill bank according to your actual machine setup. The help section covers this pretty well.
10/12/23       #8: Drill Bank Operation ...
gary
We use the drill bank to drill 5 adjustable shelf holes at a time, hinge screw holes, assembly holes and much more. You don't have to tie up tool changer capacity with boring tools.
6/18/24       #9: Drill Bank Operation ...
Harry  Member
Hi there Team
I am from Sydney Australia.
We bought a machine quite a while back.
Figured this thread is for Enroute and Anderson Selexx CNC machines, I thought of continuing with the same thread.
I am using Anderson Selexx Eco with Enroute FanucOI - Selexx10x7 driver.
I am also a newbie to CNC and have been learning the hard way by hit and trial methods & with the help of all you good souls.
Facing a little issues for the last 2 days.
1. When the machine drills the hinge hole its not deep enough, still needs approx 2mm deep. I havent changed any settings at all , it just happened all of a sudden.
Please suggest to how to increase the depth manually or how to touch tool the drill bank.
TBH I have just learnt to use Touch tool function only a month back :)
2. My spoil board moves sometimes. I have checked the vacuum, cleaned the filter etc etc. Sometimes it works and at times it doesnt. :( gives me hard time.
For reference :
Machine : Anderson Selexx Eco
Designing Software : Cabmaster
Nesting Software : EnRoute
If I can get a Step by step guide will be highly appreciated,
TIA
Harry
    • Machinery Associates
