Spoilerboard vacuum zones
6/18/24
Ben Member
I use trupan for my spool board, with a 10hp regen blower for vacuum. The vac is a bit undersized I know, but I have power constraints.
I have 5 zones - each with a valve. I’m thinking about ways to improve the holding power when cutting smaller parts, and it occurred to me that I could groove most of the way through the spoil board with a 3/16” bit and then pour in some low viscosity epoxy. This would keep the vacuum focused in the specific zone and prevent lateral losses.
Has anyone tried this? My primary worry is that I suspect the trupan is probably a bit compressible and the epoxy wouldn’t be, so it could create an uneven surface when the vacuum is on. I could maybe use expanding foam or something.
Thoughts?
6/18/24       #3: Spoilerboard vacuum zones ...
https://allstarcnc.com/
6/18/24       #4: Spoilerboard vacuum zones ...
Or you can cut your spoilboard into the zone sizes, edge band the fix to the bed.
A vane type vacuum pump will give you more hold than a regen for the same current draw. I have a Busch 7.5 hp that is sufficient for my 4 x 8.
In the meantime you can cut with an onion skin and finish with a .015" finish pass which is great at cutting small parts.
6/18/24       #5: Spoilerboard vacuum zones ...
jerry Member
I cut mine into the zone size then use 6mm sintra between the sections edge banding would be good also
6/19/24       #8: Spoilerboard vacuum zones ...
BH Davis  Member
My 4x8 table has 4 zones at 2' x 4'. I have a separate 2'x4' piece of Ultralite MDF on each of the 4 sections. The MDF edges are covered with 2 coats of Titebond 2 applied with a small roller.
7/4/24       #9: Spoilerboard vacuum zones ...
Pete Member
Website: https://wattsan.com/
Grooving the spoil board and using low viscosity epoxy could help focus the vacuum, but your concern about uneven surfaces due to the compressibility of Trupan is valid. Instead of epoxy, you might want to try a more flexible sealant that can accommodate the slight compression without creating high spots. Expanding foam is an interesting idea, but it might be tricky to control and could lead to inconsistencies; a silicone-based sealant might offer a good balance of flexibility and durability.
7/16/24       #10: Spoilerboard vacuum zones ...
Mike McClaran
Website: http://www.bettervacuumcups.com
Sounds like a lot of work. Or you can use these tiles to greatly enhance your holding power. These tiles also greatly enhance the holding power of our DS cups.
https://bettervacuumcups.com/tiles-rubber/
    • Better Vacuum Cups, Inc.
    • Limtech Industries, Inc.
