CNC in high end residential
7/16/24
John Bishop  Member
A bit on my history. I am a professional consultant. I owned an architectural woodworking shop for (32) years. I got sick and had to close it down. By some will of God I am still alive (4) years later after a MRSA infection in my spine returned (16) times.
My current client is getting ready to buy a nice 5 x 10 with loading and unloading. My job has been to get his Cabinet Vision house in order. By setting up construction methods. Building them a complete library based on the existing products they build.
His business is high end residential. I am curious what you are doing with these CNC routers. His plans would include the following as a main stay.
• One-piece MDF doors
• All plywood cutout, drilling & machining.
• Other assorted MDF doors and end panels.
• I intend on building him a nice library of MDF mantels.
• MDF columns
When I owned my shop, we did a lot of curved work. Especially curved moldings. Our process was simple, cut out shape with routers and pattern bits. Then run through a Micron Molder. Is this still the preferred method?
A huge part of our process was getting an accurate blank to run through the Mikron. I would imagine this is much easier with a CNC machine. Do you shape on the CNC. That is curved crown on both planes, radius casing and head jambs? Is this a reasonable thing to use the CNC for?
What else are you using your CNCs for in the residential arena? My current client has an excellent working relationship with local builders, I would imagine he can gobble up any miscellaneous millwork in the houses. Do you use your CNCs for this type of work?
Thaks for your help.
DJB
7/17/24       #2: CNC in high end residential ...
Yes, we do residential, although our main focus is high end commercial, hospitals, casinos, churches and the like. We do a bit of curved mouldings. Our newest router has a moulder head on a rotational axis(3 axis). our older router can do this as well with a moulder aggregate using the C axis for rotational turns. If the radius is too tight for the standard straight line HSS moulder knife, we can make the crown, casing, shoe mould, ect with ball end mills. The router is integral to making our millwork. We do it all from entry doors, windows, cabinetry, and architectural features. Could not do it without our machines. Everything you mentioned has been done for 25 years or more on CNC machines. Did you have anything specific you wanted to ask about?
7/20/24       #3: CNC in high end residential ...
Does anyone do midgrade?
I can't imagine a modern cabinet shop being competitive without a cnc. In any segment.
8/10/24       #4: CNC in high end residential ...
I had no idea that one piece MDF was ever considered high end. It certainly wasn't in my region.
    • Machinery Associates
