cnc spindle manufacture for scm
9/20/24
Rodney Member
anyone know what brand this spindle it is? came from an scm router, I would assume that its manufactured in Italy
View higher quality, full size image (569 X 358)
View higher quality, full size image (439 X 290)
9/20/24       #2: cnc spindle manufacture for scm ...
Marc Member
Website: http://www.t-toolusa.com
Rodney, the OEM brand spindle for SCM is made in-house by Hiteco, just like Biesse and HSD.
9/21/24       #3: cnc spindle manufacture for scm ...
Been to the factory. Food was excellent! I'm sure the spindles are fine with proper use. They've made thousands of them.
9/26/24       #4: cnc spindle manufacture for scm ...
AdeaLeka
Website: https://wattsan.com/
The spindle in the image appears to be from an SCM router and could likely be an HSD spindle, as HSD is a well-known Italian spindle manufacturer commonly used in SCM machines. The design and labeling hint towards HSD or a similar Italian brand.
9/26/24       #5: cnc spindle manufacture for scm ...
Rodney Member
Thanks,I will try to reach out to them, I am looking for a parts sorce.or a direct replacement with going thru scm direct
9/30/24       #7: cnc spindle manufacture for scm ...
Jacob shinobu
Did you find what you need? I am also interested in these details.
9/30/24       #8: cnc spindle manufacture for scm ...
Rodney Member
No not really, I emailed heitco they fowarded it to scm they are the ones that are the the one that responed back, They sent me a quote for $19, 611.00 quote for a replacement , ask I there where parts available or who made the spindle no parts available and said it was made by scm... big secret I guess, got someone that could probably do the rebuild bearing wouldnt be a problem any special parts might be or could possibly make them.
9/30/24       #9: cnc spindle manufacture for scm ...
Rodney Member
If you find out anything let me know I will do the same, we are loacated in the dallas area havent been able to find anyone local that actully dose these, my Freind is a machinist with 50 yrs exp he says there couldnt be that difficult.
    • Country Saw and Knife
