Vacuum Pump for a 5x10 router
12/30/24
vssvvss Member
Hello.
We recently got a shopsabre 510 with a v4 vacuum hold down. It works ok (could do with more holding power) but is super loud. I was wondering if you guys could recommend a more quieter better solution. I could go with the becker vtlf 2.400 from shop sabre but its a little on the expensive side and the maintenance and reliability worry me. Alternatively I found a used vtlf 2.250 for half the price. But then the maintenance and durability are still an issue. I mention the reliability not from personal experience but rather from reading the posts here.
And then there are liquid ring pumps like the dekker v max and the oil lubricated vane one like the dura vane.
I am sort of lost.
We cut all kinds of stuff and more holding power would be great. I would just like to get the best bang for the buck. Thank you
12/30/24       #2: Vacuum Pump for a 5x10 router ...
Beckers are good but noisy. They do last a long time though.
I also have a 40HP Travani and it's quieter than my 10HP Becker.
When we cut 4X8 on a 5X10 table we cover the open area with scrap. Makes a difference.
12/31/24       #3: Vacuum Pump for a 5x10 router ...
If I were buying a new router tomorrow, I'd be shopping for smaller pumps and multiples. And probably wanting more than I need.
PLC controller to manage the pumps and put them on line, or take them off as needed.
Sometimes you're doing something dicey, and you need all the vacuum you can get. Sometimes it's a sheet of melamine with nothing but large parts that need minimal suck.
Smaller pumps also means if one goes down, you can still do the work if one fails for whatever reason. Also depending on what you're paying for electricity, you can save a ton money with lower demand charges starting smaller motors.
Up front it'll cost more though.
I wish I would've set up my compressed air in a similar fashion. Multiple small compressors instead of one big one.
12/31/24       #4: Vacuum Pump for a 5x10 router ...
I looked into this several years ago, thinking I should put a VFD on my 30HP pump.
Turns out that the more vacuum you pull the less power you need. Makes sense because you are not moving as much air. I have not verified this with an ammeter but it'd be interesting to do so.
Maybe if I have time to hook up my 40HP next year....
1/3/25       #5: Vacuum Pump for a 5x10 router ...
vssvvss Member
Thank you.
Any thoughts on becker alternatives?
1/3/25       #6: Vacuum Pump for a 5x10 router ...
PWW Member
I started with 2 Beckers for my 5x10 because they came with it. They both started getting real loud after a few years and we replaced 1 in it's 7th year. Thing is, dry vanes are designed to destroy themselves because they are based on dry friction. You can replace the very expensive vanes frequently, but they eventually wear out the casing.
So we replaced the one with a Busch Rotary Claw. It's quiet, sucks good and, in theory, should last a good long time with an oil change every year.
I 2nd the advice of multiple smaller pumps. We still have the 1 vane pump but mostly just use the claw. If we need extra hold down, everyone puts on their ear protection and we fire up the vane. I sleep better knowing that if 1 goes down we are not dead in the water.
1/22/25       #7: Vacuum Pump for a 5x10 router ...
Art Ross Sponsor - Advanced Machinery Automation
Website: http://cosmecsrl.com/en
Dry vein pumps are kind of loud and get louder as the veins wear out.
someone above suggested covering the unused part of the table this will be a big help.
If it does but its still too loud you can run PVC pipes and move the pump into another room our build a dog box for it and pipe the exhaust out of the building.
I can sell you a brand new 5.5kw dry vein pump like Becker for $2,940 or a 7.5kw for $5,550.
    • Machinery Associates
    • Country Saw and Knife
