edgebanding narrow strips (1.5" or so) on both long edges
12/18/24
Matt Member
We have a line of product that will have some melamine (and similar materials, such as gloss acrylics) that we need to be able to produce some 1.25 and 1.5" wide strips banded on both long edges.
Most edgebanders, including our Homag Servo bander, won't accept anything under about 2.75" wide safely, which means we have to resort to odd tactics to get it done, such as taping the narrow strip that needs the long edge banded to a wider board to turn it into a board wide enough to be held safely by the bander's track.
Are there any other options, tools, jigs, tabletop machines, tactics, etc that anyone else has used that will help get this done?
Usually we are banding these things using standard hot melt glue and 1mm or 2mm pvc.
We also have a Festool Conturo which looks like it might have some potential here but my creativity fails me here.
Thoughts?
12/19/24       #2: edgebanding narrow strips (1.5" ...
If you only need one good wide edge maybe miter fold them.
12/29/24       #3: edgebanding narrow strips (1.5" ...
Bozzy Member
We do many pieces that are 1-1/2 to 2" wide and 7 or 8ft long. We use green tape to join the two pieces together. We also find this annoying, but it's still quicker than anything else we've tried and the results are consistent
1/3/25       #4: edgebanding narrow strips (1.5" ...
NeonVortex Member
In addition to hot melt adhesive and PVC, you can explore other edge banding methods, such as edge banding tape or other types of edge banding materials, which may be more suitable for handling narrow strips.
1/10/25       #5: edgebanding narrow strips (1.5" ...
Tom Member
I would cut a wider strip to say 4", lip the 2 long edges, then take it back to the beamsaw to cut down the middle to get two bits at 1.5" and tape them only once. you might be doing this already though.
Cant see the Festool Conturo being quicker as you would need to clean the edges and trim it after manually?
1/13/25       #6: edgebanding narrow strips (1.5" ...
Matt Member
Tom, yes, we do occasionally do this (band it large and rip into smaller strips).
The main reason I would reach for the Conturo isn't so much for speed but for safety. Running small parts like this through a bander using tape adds in a lot of room for human error and a bander crash.
    • Machinery Associates
