Stratos pro post.
2/28/25
Nathan Member
Hi.
Is it possible to control the diffrent vacuum zones on an Anderson stratos machine via gcode. The post being set-up to call out the zones based on sheet size. I do have a list of Mcodes for the diffrent zones. If so, could someone provide a sample gcode to show what that would look like?
Thank you
3/5/25       #3: Stratos pro post. ...
The trick will be calculating which zones to use. Turning them on and off is dead easy.
You could have 2 copies of the post, 1 for 4X8 and 1 for 5x10 for instance, and just list the M codes in the opening string(s) of the post and then turn them off at the end. There should be a single M code to turn off all vacuum areas.
You can probably edit the post in a text editor. Make sure you make backups!!!
3/17/25       #4: Stratos pro post. ...
davis02 Member
Many CNC routers, including Anderson models, allow for vacuum zones to be controlled through custom M-codes.
3/17/25       #5: Stratos pro post. ...
Nathan Member
I have edited some of my Gcode for files that I use frequently (like spoilboard shave) to turn on the desired zones. I guess im hoping to eliminte the potential for error by adding a variable to my post to be able to call the zones based in sheet size.
