Since even before getting the CNC (just recently) I kept reading about panel processing times around 5-6 minutes.
We just did a run of 22 pieces of Columbia 7-ply for some relatively simple vanities, and our average run time (From Go Button to Sweep) was almost 22-minutes per panel with onion skin on the small parts (that's basically 2-panels per hour once you factor in loading, breaks, talking, etc).
I mean, could we do them in 6-minutes? Sure, I could throw them through at 24k and 1200/ipm with no onion skin, but the edge finish would be terrible with extensive fuzzing of alternating plies and we might have to duck an airborne small part here and there.
We have settled on 1/4" 2F Comp at 16,000 / 180ipm, because it seems to give the best results. Anything faster and we get terrible fuzzing of the ply edges. We've tried every combination of climb/conventional possible. We've tried multiple passes and single pass.
Our Block is half as big as our 21 spindle so we're dropping multiple shelf and dowel holes at a time.
What aren't we doing right? Are 5-minute panel processing times only for melamine? Is 20+ minutes on a sheet of plywood normal?
Don't get me wrong, we still walk away from that machine every day shaking our heads at how much wasted labor we have had over the years before we got the CNC, especially for our origami solid surface processing.
What used to take 6 individual processes at 4 separate stations (and some of those processes were pretty back-breaking) now happens in 1/10 of the time at one station.
But, because we don't know what we don't know, if we can somehow speed up our panel processing times, we sure would like to.
