scm 240
5/21/25
Randy Hofer Member
hi all. i have a2001 scm routech record. anybody out there got one also. im trying to manualy remove a tool but plc61 head selection comes on. i have two spindles. thanks!!
5/23/25       #2: scm 240 ...
Michael Folan
Hi
I don't have the exact machine but I had a similar problem a while back.
I'm sure you wrote a simple programme to see would the machine do the change itself?
My fix, after ruling out anything in the electrical cabinet and dust hood, was the bank of solenoids were faulty. The piston that slides up and down was dirty.
I ordered the solenoid from SCM to have in the spares box but I turned off the air and sprayed WD40 into each of the quick release air fittings one by one and re connected them. Its been fine the last 2 years.
5/26/25       #3: scm 240 ...
randy hofer
hi thanks for the shout back. so im trying to manually take out the tool to service the inside of the spindle. in mdi mode. but being i have two spindles i have to do a head selection in iso . what kind of cnc do u have?
    • Country Saw and Knife
