HELP ON MY HOLZMA BEAM SAW MACHINE
4/12/16
chuks Member
Website: http://www.iwlimited.com
Hi guys,
I really need your help on some technical fault recently developed in my machine - HOLZMA HPP380 BEAM SAW.
The machine come on fine and so also its booting system. But while trying to cut, the main saw/scoring blade is not moving to cut the material. i've also tried to check if the blade is rotating and i can confirm its rotation. There seem not to be any error message on the machine
I will appreciate your ideas on the possible cause and how to resolve this issue.
Many thanks,
Chuks.
4/12/16       #3: HELP ON MY HOLZMA BEAM SAW MACHINE ...
daveguru
Check the safety circuit micro-switches, very probably a dusty or no good switch
8/12/25       #8: HELP ON MY HOLZMA BEAM SAW MACHINE ...
mech Member
I really need your help on some technical fault recently developed in my machine - HOLZMA HPP380 BEAM SAW. Related to SPD. Holzma engineers checked it online and did everything related to SPD. Actually the SPD is not engaging. SPD is not coming down. They asked to change the Stop valves which we changed. We tried to check manually by valves assembly and it is performing well. What are the possible cause. Can some one help us
