scm pratix s15
10/16/25
jolly cabs
the spindle will not spin and it will not release the tool I can hear air leaking from around the tool
10/17/25       #3: scm pratix s15 ...
You locked up the spindle. If it has a cartridge, you can replace it yourself. If not, you will probably need a tech. Either way, you are replacing it. Last time I saw that happen it was self inflicted by bad programming.
