Weeke homag cnc drilling using aspire or vcarve
8/2/18
anthony Member
hello all hope your doing great
i am using aspire to nest my parts on my weeke vantage but i cant use my drill box to drill holes ? anyone is facing this problem ?
hope you can help me with that
thank you all
8/3/18       #2: Weeke homag cnc drilling using aspi ...
I do not think Aspire has the ability to utilize a drilling block. Best you can do is route them. There may be a work around to drill one at a time, but that's a big maybe.
8/4/18       #3: Weeke homag cnc drilling using aspi ...
Arto
If aspire allows dxf export with different layers, you could use woodwop for the drilling and aspire for the cutting.
More work for sure, but will get it done. Depending what you are trying to achieve it might be a viable method.
8/4/18       #4: Weeke homag cnc drilling using aspi ...
If you post this question on the Vectric forum I think there is someone who can write code for you to enable the use of your drill block.
8/7/18       #5: Weeke homag cnc drilling using aspi ...
steve Member
v-carve can output .mpr (woodwop) files directly (.ply too if i'm not mistaken). open in woodwop and add your drilling.
8/13/18       #6: Weeke homag cnc drilling using aspi ...
Marek Skotak
Website: http://www.cadcam-softcz.cz
It is possible, but you to have two postprocessors and join NC code.
10/23/25       #7: Weeke homag cnc drilling using aspi ...
Richard Baier
Website: http://info@bristolmillworkinc.com
I know I'm late to the party, but yes it is possible. I have a Post for using your drill bank in Vectric Aspire. However its not perfect. It only uses one of your drills on your drill block. You can either modify the post in notepad for your required depth and diameter bit required or you can do this in woodwop in the variable setting.
Let me know if you still are looking and i'll send you the file.
You also have to merge the file into all of your cutting files as well. Also done in woodwop.
You can also export your project as a dxf and import the dxf into woodwop to use all drill blocks. This also comes with complications. Vectric converts all circles to polylines in autocad. and you have to reconvert all the polylines to circles. I also have a script to make this easy in autocad.
    • Country Saw and Knife
    • Machinery Associates
