SCM Flexstore ELR and 3/4" and 1/4" MDF
2/19/26
David Reed
Hello,
I was wondering if anyone uses/integrates an SCM flexstore in their shop.
We are considering it for our shop in combination with 2 SCm M600 machines
It seems like it could be a major hangup since if the system goes down, the machine(s) basically go down with it, and then everythign else is also trapped inside it.
We are trying to justify the cost vs things like,
1)tight storage spacing
2)slow panel movement (about a minute to move a single panel into the storage,
3)picking up 1/4" MDF,
4)the possible number of times this goes down in a year, and when it goes down i would think it could be down for days at a time easily.
Anyone who has been around or used one before, any input would be appreciated.
Thanks in advance
2/23/26       #3: SCM Flexstore ELR and 3/4" and ...
Chet Member
I think in most cases the machines in the storage system can operate on their own if that have to. Just not sure about the one you mentioned. Having local techs to work on it would help.
2/24/26       #4: SCM Flexstore ELR and 3/4" and ...
Alex_Zhang Member
Hi David,
Chet makes a great point about being able to run the machines independently. You can usually bypass the storage system and manually load the M600s if the Flexstore goes down, but it definitely throws a wrench into your floor flow and defeats the purpose of the automation.
Your concern about the 1/4" MDF is completely justified. Vacuum lifters on these automated systems can sometimes be very finicky with thin, porous materials—either dropping them or accidentally picking up two sheets at once. Before making a decision, I would highly recommend forcing your SCM rep to do a live demo specifically using your 1/4" MDF.
Has your rep given you any solid numbers on guaranteed uptime?
Best,
Alex_Zhang
2/24/26       #5: SCM Flexstore ELR and 3/4" and ...
David Reed
thanks for the input, i have asked questions like "how often do they go down", but i have only been given vague responses, no real numbers like "average % uptime"
we do quite a bit of 1/4" mdf and plywood and even on auto loader machines its had plenty of vacuum issues like that before (generally picking up too many).
i will try to check back with SCM on these topics you mentioned.
    • Machinery Associates
    • Limtech Industries, Inc.
