Looking for Selema / Vickers F1PC Software for DBC III Servo Drive
9/14/26
Bryan Krossley Member
I’m looking for a copy of the old Selema / Vickers F1PC DOS software used with the F1 Formula / DBC III servo drives.
The drive I’m working with is a Vickers / Selema 70-DBC-III-F18 on an older CMS CNC router with OSAI control.
One of the servo motors was rebuilt, and I need to perform the resolver alignment / motor phasing procedure. The Selema documentation indicates that this was done using the F1PC software, through the drive’s RS-422 communication port.
I have found references to:
F1PC Rev. 2.2
F1PC Rev. 2.3 / Rev. 23
I would be interested in any version of F1PC that supports the F1 Formula / DBC III drives.
I do not necessarily need an original floppy. Any of the following would be useful:
F1PC installation folder
F1PC.EXE
ZIP archive
floppy disk image
backup from an old service laptop
related configuration or support files
SELINT-1 communication documentation
If anyone worked on older CMS, Selema, Vickers, or F1 Formula servo systems and still has this software in an old service archive, I would greatly appreciate hearing from you.
I am located in the United States and am trying to get this machine operational again.
Thank you,
Bryan
    • Country Saw and Knife
