Hello all,
We have a HOLZ-HER LYNX 7511 (2016, CAMPUS / NC-HOPS control). We cut 3D relief (wave) panels in MDF. One panel takes about 1 hour, and some jobs run 3 to 4 hours.
The problem: on these long jobs our vacuum pumps run the whole time and get very hot. For these jobs we would like to turn the vacuum pumps OFF and hold the blank with screws into the spoilboard, while the spindle and the axes keep cutting.
We emailed HOLZ-HER USA on November 9 but have no answer yet.
Questions for Holz-Her owners or techs:
1. Have you run a Lynx (or another HOLZ-HER with CAMPUS / NC-HOPS) with the vacuum pumps off? How did you do it - a setting in NC-HOPS or the machine, a switch, or a parameter?
2. Does the machine stop or refuse to start the program when there is no vacuum (a vacuum monitor / pressure switch)? Is there an approved vacuum-off or clamping mode for that, or does it need a HOLZ-HER technician? We do not want to bridge or jumper any switch.
3. Can we run only one pump, or only one vacuum zone, to reduce the load?
4. Is it normal that the pumps get this hot after 1 to 4 hours of continuous running? What should we check (filters, oil, cooling air, leaks in the spoilboard or table)?
5. Any tips for screwing a blank to the spoilboard on this table (where it is safe to screw, spoilboard thickness)?
6. What vacuum pumps came on a 2016 Lynx (make/type), and what pump temperature is normal for continuous running?
Thank you for any help.
Amir
